![]() | Home > Technical (L322) > Replacement cats |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'm sure there are good ones on ebay just as there are probably bad ones.
I guess they'd be the exhaust cats for a 2004 V8.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Euro Car Parts stock catalytic convertors.. |
But which ones, there is more than one seller on there. But yes, any motor factors will also sell Catalytic converters. |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
There is a known issue with the early cats on the 4.4 V8's where the front ones (just under and forward of the front doors on the bend up to the manifold) split on the top front seam - a good mechanic will be able to weld them if thats all thats wrong (rather than the baffles internally having gone and rattling inside)
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
You can sell your old ones here:
On a serious note, you can actually weigh the old ones in for scrap if you replace them. I got £30 for a small one a couple of years ago. They're full of precious metals. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
When I bought my 2002 v8 it had had a pair of aftermarket cats fitted, chopped into the existing off pipe, creating an also vulnerable leak joint in mild steel. They were rattling (both) and were leaking on the joints. I looked at another pair of aftermarket ones, but was advised they are often only built to last a few years. I decided to fit an original pair ie genuine, from a reputable dismantler. You often get a 3 month or sometimes one month warranty, but if you 'buy it now' as opposed to auction win an item on eBay, you can return them if they are not fit for proposed etc. (very useful point) you could look for a complet exhaust, but they are as long as the car! (Almost) so I got my pair for about £250 not cheap, but they were from a very low mileage car, just 30,000 I asked them for extra bubble wrap so they didn't get mishandled during delivery. I fitted them and used a sleeve piece that I ordered again through eBay, to slide over, each piece stainless, and about 4inches long, and with a little assembly paste, they are perfect. You might get them with O2 sensors, and then you have a spare set. (To sell on?). Aftermarket cats have no secondhand value, even as scrap. And are also often made of mild steel |
