![]() | Home > Maintenance & Mods (L322) > Front rubber protection Bar |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Can anyone help with me finding fitting instructions for the front rubber Brush Bar. I have done a search with no luck |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
All accessory fitting guides are in Rave, you can download it from the Wiki....
I have Rave and have gone through all the sections with no luck, can you please advise on the section and page number.
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
it's on rave under accessory fitting instruction and it's also on Topix.
My problem is I dont have a cd/dvd drive on my laptop so have to go through each pdf section. I still cannot find the fitting guides but I know what to look for now. The Topix link is perfect, downloaded what I need. Thanks for the help |
I have downloaded rave as an iso disc image file and all good with a dvd drive emulator |
unpack the iso file and copy the contents to a folder and it will work without the emulator. |
| psgk Member Since: 18 May 2011 Location: Chelmsford, Essex, United Kingdom Posts: 48
I'm pretty sure you use to be able to download various accessory fitting instructions from the main LR site.
You still can I posted the link to Topix above. |
| All times are GMT |
