![]() | Home > In Car Electronics (L322) > Bluetooth retrofit |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Good day.Thanks for your last.u are are right mic has only 3 cables.Understood that swapping of cables 19-21,depending on which drawing u will use, does not affect function of mic.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Hi.
Good mrng.
I used the chart in my earlier message and my microphone works fine.
Good day.I changed mic with a new one but still i cannot be heart.Any idea what i have to further check so try solve this problem?????
The only thing I can think of is that you have a break in the wires somewhere between the ULF and the front of the car.
I was hoping to be something simpler since for me seems very difficult to make a new mic line.
Where did you get the first mic from ? Was it in the car already ?
No the mic was not in car.Bought it together with ulf.Second one bought is a new one.Have seen the site and noticed about mic connection under the centre consol.My car has ashtray instead of cup holder.So i am afraid that order reach the overhead mic connection i will have to remove the all console or not?just few parts of the console and that's it?
Sorry, I've never took the console apart.
Hi there.Have connected a mic directly in ulf and normally worked.So decided to check what is happening under the centre console which easier than take it off that what i was expected.
I've never looked under the console, sorry.
You are looking for C2044 on this diagram, with those coloured wires going in and out
Thanks your last.I tookoff once again centre console and i carefully relooked maybe for more than an hour almost all the looms in there but i found not and any connector either free or connected with relevant colors or even with just 3 cables.Afraid that i will not escape the visit to workshop.Bad luck |
