Home > Technical (L322) > Diagnostics and Programming
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
I've been used to having a good degree of control over my old Discovery 2, through a Hawkeye diagnostic device. Part of the reason for buying one was that it could be upgraded to cover other vehicles, and so I duly added the L322 to it. Yes it can fault read and reset, but what I didn't realise was that there was no programming at all possible through the Hawkeye.
I don't want to sell up, as I still look after my parents D2, but I now find myself needing to do something to get control of my L322.
I've seen the IID tool is quite widely used here, but are there any others I should consider?
Alternatively is there anyone here who for beer money would be able to let me take a roam though my L322's brain and set a couple of preferences?
Many thanks
MW
Post #328455 18th May 2015 1:15pm
Zirconblue
You can actually get the official JLR system.
You'll need to buy the cable £450 for a genuine one (there are fakes but they often dont work)
Then you can subscribe to SDD Software via Topix, on annual, monthly daily hourly rates. It ain't cheap though!
There are ways around the software subscription, but you'll have to do your own research for that.
Post #328506 18th May 2015 7:44pm
Discotigger
IID Tool is by far the best bit of kit to get. 'It does everything it says on the tin', to coin a phrase. Thumbs Up
Costwise, it's only about £370 odd for the BT IID Tool, so cheaper than the JLR plus Topix option. The IID Tool, though, is Vin locked to one vehicle, but you can get extra Vin Licences for about £60 per additional vehicle.
I've got one myself and I can vouch that it's a must have tool for any FFRR owner! Bow down Bow down
Post #328516 18th May 2015 8:22pm
Rangeyman
Re: Diagnostics and Programming
Unnecessary quote removed
If you were a bit nearer my mate would have been able to sort it for you.I could always ask him if you are desperate as he does get around a bit am sure he wouldn't sting you if he was passing nearby!
Post #328677 19th May 2015 7:37pm
mike whiskey
Thanks Rangeyman.
I have been known to travel a bit too! I guess the question is where about is he, and where does he travel, and what are the chances of the two of us crossing paths!
Post #328717 20th May 2015 7:59am
Do you travel Gloucester way?
Post #328719 20th May 2015 8:05am
Rangeyman
Have spoke to him but he doesn't get down your way as his work is mainly north now !
Post #328957 21st May 2015 8:38pm
