![]() | Home > Technical (L322) > RR Vogue 4.4 2003 RHD. Passenger door electrics |
velofelo Member Since: 21 May 2015 Location: uk Posts: 6 ![]() ![]() |
HELP.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
If you need a passenger control module, I believe that's the bit with the the window switch on it, on the pass door, I have one I bought to try and fix my dead mirror, which it didn't! You might have a loose connector cable in the door jam, ie the rubber sheath from body to door carries the wires, and they have a pull off termination. Either in the door or the kick panel. If you want the module, it s£10 posted. PayPal? |
Hi Martin
Thanks John Boy
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
HI on my 2003
Who's Martin? |
thanks again
Sherlock Holmes hat on and a good worry later, head scratch, a mull and a long stare......... On reflection I did not remove the electrical connector clips on the door wiring loom while changing a broken door lock cable, that had the well known seized nipple problem, and I dropped the door card , not badly but it was stopped from falling by the loom connections. It MAY be that one of the wires (multiple) has been broken although no visible evidence of that. Is there a clever way to continuity check the door loom ? the connectors (c2508 etc Thanks espaceboy !) don't allow you to see which pin is dedicated to which wire. Is it practical to dismantle connectors to view inside for breaks? ( I have to replace the door card after every try to keep the car on the road, so getting to the connector again to see is difficult and impractical, maybe someone here has done that ? Failing that, Any good sources for a new loom ? My gut feel is that its a broken wire and not the passenger door control module I am a little nervous of second hand looms and switches as I may be jumping out of the frying pan into the fire!
I would get a loom from a scrap car and splice it in. Before that try working the switches while the door card is unclipped and apply thumb pressure to the back of the switch pack connector, give the loom a good wiggle and shake and see if you get intermittent operation. I still think that the wiring to the connectors will be ok, it will be the internal crimps on the switch connector
Oh and try this on both doors especially drivers door switch pack. You mention that you have had booth front door cards off
Many Many Thanks for your great advice and apologies for the delayed response but I was awaiting parts and a week's holiday intervened. I attacked the problem again this morning.
well done mate! |
