Home > LPG > Coolant change - does this disturb the LPG system?
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
I am looking to do a coolant change on my M62-engined RR soon as I dont know the age or condition of the current antifreeze. However, I am aware that LPG systems use a water heater to preheat the gas before injection.
Are these systems separate (ie. it works via a heat exchanger with the engine) or does the engine coolant actually divert through the LPG gubbins? If the latter, what procedure do I need to follow to refill and bleed it properly?
thanks,
Matt
Here's a picture of my setup. I believe the make of the system is Stag.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #328978 22nd May 2015 1:53am
Just the normal procedure to change the coolant, it will self bleed fine on it's own...
Refill the system slowly as they are prone to air locks, and check it for a few days afterwards... this is nothing to do with the LPG though...
Thumbs Up Pete
Post #328990 22nd May 2015 7:54am
Pete, would it be best to do that on petrol though? Doesn’t the water temp effect the gas/petrol turn over point?
Post #328997 22nd May 2015 8:57am
Don't think it will make much difference Craig, If converted properly (and most are these days) the take off for the vaporiser is teed from the heater pipes so that the water flows correctly, as the heater flow is not controlled by the thermostate it doesn't usually get an air lock unless the system has been mounted too high in the engine bay, Matt's look low enough so he shouldn't have any problem, it looks like he's also got twin vaporisers so it would work OK even if very cold... Thumbs Up Pete
Post #329019 22nd May 2015 10:22am
Thanks Pete, as you can gather i know little about LPG Bow down Whistle Thumbs Up
Post #329021 22nd May 2015 10:35am
mat777
Thanks chaps - so by sharing the heater water, the system will drain and refill as normal when the coolent is replaced carefully? (or is the heater system's water separated from the engine's water?) NW060
Post #329031 22nd May 2015 11:42am
