|  | Home > Technical (L322) > Slow power drain |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Nothing to stop you disconnecting the battery -ve terminal and inserting an ammeter in between the battery -ve terminal and the end of the -ve cable end you have just disconnected.
|  23rd May 2015 8:53am |
| Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47      | Thank you. I like the idea of LED lights. Must I change the fittings or can they just be plugged in? | ||
|  24th May 2015 12:58am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Replacement led bulbs can be obtained from eBay etc. no need to change fittings.
|  24th May 2015 5:33am |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | I can't remember without going to look at my car. But don't the interior lights 'fade out' when you lock the car?
|  24th May 2015 8:22am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882    | my smd panels fade out.... ... - .- -.
|  24th May 2015 8:29am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | All my interior leds seem to quite happily fade out. It's a good point about the possible shortened life through dimming but mine have been in 3½ years to date, if they fail I'll just replace them, they're not expensive. | ||
|  24th May 2015 8:55am |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | As i said they'll still work, but the bulbs (or the dimmer) might not last as long.
|  24th May 2015 9:13am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | You've just about got it right.  | ||
|  24th May 2015 11:56am |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | I was more concerned about the dimmer than the bulbs, as you say the bulbs are cheap enough (and if they do blow next week 3 years use from them isn't bad), but i'd baulk at buying a new ECU. | ||
|  24th May 2015 6:08pm |
| Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47      | Final victory. The Land Rover dealers charged me $80 to tell me that there was a power drain and quoted for a minimum of 10 hours and possibly 30 hours.
|  16th Jun 2015 9:11am |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | The X5 has the same electric fan.   | ||
|  16th Jun 2015 12:00pm |
| Posting Rules
