|  | Home > Technical (L322) > Bi-Xenon Headlamp issues |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263      |
 Hi,
|  22nd May 2015 3:39pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | i'm sure i read somewhere that the bulbs should be replaced in pairs , if that is the case then you can get decent ones of ebay for around £18 a pair or pop round to me in swindon cos i have some you can have for nothing.. ... - .- -.
|  23rd May 2015 12:29pm |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804      | +1 to what stan says, you should always replace the bulbs in pairs...and make sure that they both have the same rating, i.e. both 4800K, both 6000K, etc.  | ||
|  23rd May 2015 12:41pm |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263      | Thanks,
|  23rd May 2015 5:49pm |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | The igniter units used to be the common failure on the Jaguars, (i'm assuming the RR will use pretty much the same parts), people usually found out it was the igniter after replacing the bulb and ballast. | ||
|  23rd May 2015 7:05pm |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804      | If you remove and disconnect the sidelight unit, you may get enough space to get the ballast out, but it would probably be best to take the whole headlight unit out. Plus you could check that it is only the ballast, not the igniter that's at fault. You would need the headlight out and disassembled to replace the igniter if that's the problem.
|  23rd May 2015 7:41pm |
| Posting Rules
