Home > Technical (L322) > Breakdown - Mass Air Flow Sensor? (Update - Blown Turbo!)
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Just getting off M25 yesterday after an hour on the motorway without problems or symptoms. Tried to accelerate up the off ramp. Load 'pop' sound then no acceleration and wouldn't go above 30-40mph. Whilst running it is very smooth. Just no acceleration.
Pulled over checked turbo hoses. OK. Called AA. Fault Code: P010C Air Mass or airflow sensor B. Low signal. Amplitude too low. AA man unplugged the sensors but no improvement. Lots of black smoke.
Car now on truck on way to main dealer. Being Bank Holiday no idea when it's going to get looked at.
Any thoughts? Could this be EGR Valve or Turbo related or will changing the sensors do it? The 'pop' sound just before is a bit worrying Big Cry Just hope it's covered by the extended warranty I have.
By the way AA were very good. First response within an hour. Took me to Enterprise car hire so I could pick my brother up from the airport then I went back to car and Flat Bed trucked turned up an hour later. All that on a Bank Holiday Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329241 24th May 2015 7:14am
Mikey
Still sounds like a turbo hose. It would be worth taking the hoses off, and checking them fully Thumbs Up
Post #329243 24th May 2015 7:34am
Nomad
Thanks Mikey.
That was my first thought. Believe or not I had spare hoses with me and changed them both on the spot. No change. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329245 24th May 2015 8:01am
Mikey
That's not so good then Neutral
There are some other rubber hoses in the boost side of things, but I have never seen one of these burst before
Black smoke indicates over fuelling, or lack of air, be it a burst hose or Intercooler, or a restriction in the intake. Let's hope it's something simple
Post #329248 24th May 2015 8:43am
If you unplug the MAF sensors the car will still start and run smoothly but will NOT have any power or go over about 20 mph. (Your symptoms) Not sure if this helps you though. I presume the airbox/filter and pipes are all secure and not split/loose.
Post #329251 24th May 2015 9:17am
Nomad
Interesting. So it could be the MAF Sensor after all and unplugging didn't help diagnose the problem? I guess I just have to wait for the dealer to find the time to look at it and hope for the best Rolling Eyes Any idea if MAF sensors are covered under the extended warranty? Thanks for comments Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329255 24th May 2015 9:22am
They are only about £75 each and take 5 minutes to fit but they rarely just stop working so it may be something related. An air leak seems most likely.
Post #329260 24th May 2015 9:33am
Nomad
Thanks. I'll just have to wait and see what they come up with. Just passed the dealer this morning and by coincidence my RR was being unloaded by the AA having spent the night at Fleet Services. I'll have to wait a few days for the diagnosis and will update then. Cheers. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329284 24th May 2015 2:37pm
Nomad
Just got the call from the dealer. It's a blown turbo. Probably £2,500. Hopefully it will be covered under the LR Extended Warranty. As it's over £2,000 they will probably send someone to inspect. Fingers crossed...... 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329632 27th May 2015 3:59pm
ebajema
Damn, sorry to hear, I hope the warranty does cover it! MY 2010 5.0 SC Galway green and sand interior!!
Post #329635 27th May 2015 4:20pm
Zirconblue
I don't see why it wouldn't be covered. Even the cheap ones cover major components like a Turbo.
Post #329669 27th May 2015 8:20pm
rar110
Censored Big Cry
Was there any sign of suboptimal performance including above average fuel consumption or black smoke? ______________________________
Post #329905 29th May 2015 10:53am
Nomad
Loud pop then no acceleration. Black smoke later but didn't notice it at first. Still waiting for warranty confirmation Rolling Eyes 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329913 29th May 2015 11:37am
marky777
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Bonatti Grey
Hi Nomad, is your MD Westover Christchurch or is there one in or around Ringwood? I am in Christchurch and have been using Westovers and cannot seem to find a local LR indy.
Hope your warranty pays up Very Happy
Post #329914 29th May 2015 11:54am
Nomad
I've been using Westover for years. Overall I'm happy with their service. Recently I've been using BLR, an Independent on the way to Poole, for oil changes etc. So far so good. They are always very busy which is a good sign.
LR Warranty have confirmed they will cover the work so now just have to wait for it to be done.... 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #329986 29th May 2015 10:31pm
