![]() | Home > Maintenance & Mods (L322) > Help with Fault Codes |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1868 ![]() ![]() |
I don't purposely seek out your threads to dis-credit anything you say. But some of what you come away is, is quite frankly, laughable.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
To be honest i didn't see Mikes post as trolling, he wasn't rude or offensive in any way, although there does seem to be an ongoing personal disagreement between the two of you.
Not trying to wind you up Craig, just setting out the FACTS. Having worked inside a main dealer for best part of 5 years, I know what goes on, book time is the maximum allowed chargeable time under a warranty claim, as confirmed above ![]() Book time for glow plug replacement on the 2.7 is actually 1.1hrs. And they are easy to replace within the allocated time, unless they are seized, at which point it becomes a PITA, due to risk of breakage post edited by moderator. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2760 ![]() ![]() |
Mine now has a permanent P040D code. Can anyone advise the resistance of a good sensor or a bad sensor?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Hi GraemeS, how hard is it to replace sensor and where is it?
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
This will probably get censored but maybe Craig and Mikey can meet at Bannockburn or Sterling to sort out and at least shake hands |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 273 ![]() ![]() ![]() |
Did you ever make any progress investigating these fault codes as I seem to have a very similar set? |
chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 46 ![]() ![]() |
I also have the same question and situation at Mike Edwards above |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 832 ![]() ![]() ![]() |
interesting, has the M62 got these "temp probe in the manifold"
