![]() | Home > Maintenance & Mods (L322) > Off road damage - oops! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6800 ![]() ![]() ![]() |
It's just screwed onto the metal frame of the step with about 10 screws.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Damn CY!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Britpart do them too i think. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7931 ![]() ![]() ![]() |
All the screws on mine are corroded and the Philips head just crumbles and falls away...... Have left mine as is.......
Yeah my screw heads were us as well. Ended up breaking bits away with plies and then undoing the screws with mole grips. All in all still only took about 10 min.
Just did a quick search for VUB001300 the Britpart ones are about £5 cheaper. Chances are they're the same manufacturer.
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
Bathgate is my favourite site to do a comp safari. I'll need to try and get back out to events |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 760 ![]() ![]() ![]() |
Glad I was working!! No doubt I would have followed you |
If you go over the top faster the front wheels will be in the air and your sidesteps will be fine........
