![]() | Home > Technical (L322) > Alternator woes sc |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
I wouldn't go anywhere in it and expect to get there, especially 180miles. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Probably on its way out but check the battery terminal for tightness for good measure!
| Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109
I will check the battery terminals just in case. I suppose luckily I have full aa cover if the worst happens. It's just the inconvenience of it really.
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
What fault code did it through up on the IID Tool ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Hi well there's some good news it made the 180miles home. I had everything turned off all the way back so there was no load on the alternator. When the light came on it was sitting at 13.7v and occasionally the battery light goes out and the voltage goes up to 14.5.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
That's good that your journey went well |
Will keep you posted when I get the price hopefully not too bad as it's the jag engine with the non watercooled alternator. The difference between theory and reality is that in theory it will work. |
Well alternator replaced with a nice shiny genuine replacement had the belts done aswell. Still waiting on price as my local indie is a friend so I get the bill when ever they have time to type it up. Another job done. The difference between theory and reality is that in theory it will work. |
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792
As Dave's alternator problem is solved I will continue the thread rather than opening a new one.
Hi Skot it was just the one alternator belt I had replaced. Excuse my ignorance it was what ever belt drives the alternator. Hope that helps.
| All times are GMT |
