Home > Maintenance & Mods (L322) > Front drive shafts.
Front drive shafts.
Quick question.
Trying to trace a slight knock and had a shake of the suspension components, noticed that the front drive shafts on both sides had slight play in them when shaken. Not a lot, less than a mm, nothing rotational, tight as a drum that way, but I could shake them a tiny bit. Am I right in thinking that this is normal wear? Or should it not move in any direction at all?
Cheers.
Mark.[/i] There is nothing that can't be fixed with a hammer😜😜
Post #329494 26th May 2015 5:03pm
Don't know if it should do it but mine do the same, it doesn't knock though....
The knock I had that sounded just like it was coming from the front, turned out to be rear hub bushes...!!!
Maybe worth a check, you need a big pry bar to put some pressure on them to check for play, preferably with the wheels off the ground... Pete
-Click here for Thread-
Post #329506 26th May 2015 6:36pm
Cheers Pete,
Didn't necessarily think it was the cause of the knock, just noticied when I was under there, but I agree the upper hub bushes at the back are on my list.
Are the shafts telescopic? Maybe I can feel the inside moving against outer part. There is nothing that can't be fixed with a hammer😜😜
Post #329530 26th May 2015 9:35pm
No but the CV's have linear movement to allow them to change length as the suspension rises and falls... Pete
Post #329547 27th May 2015 12:37am
That's probably what I can feel. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #329678 27th May 2015 8:49pm
Thumbs Up Thumbs Up Pete
Post #329680 27th May 2015 8:55pm
