Home > In Car Electronics (L322) > Towing electrics pre-2006 vs. post-2006
Zirconblue
I've got a Land-Rover single electrics kit on mine, but i'd like to change it to a 13pin (they're just better in every way!)
trouble is though mine is a 2004 car and no one lists the genuine harness anymore. Paddock list one for 2006 onwards cars. But what's the difference? What did they change in 2006? The towing ECU is apparently the same, the only thing i can think of is the socket where the harness connects to the main vehicle harness is different. Or the new harness is a slightly different length so has a different part number just because they've changed it in some insignificant way!
Post #329514 26th May 2015 8:03pm
Weegie
P.F Jones supply the LR specific 13 pin electrics. Have just fitted them to my 2005 MY FF. John
GAP iiD BT-Sold
Post #329516 26th May 2015 8:21pm
Also,
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Post #329519 26th May 2015 8:25pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I got a genuine 13pin kit for y 2003 car from a parts supplier in Belgium, from memory I toyed the part number into Google and found them that way
Post #329522 26th May 2015 8:40pm
Zirconblue
They do, however it seems to use an aftermarket ECU, rather than utilise the proper LR one, which i'd rather keep.
Post #329527 26th May 2015 8:52pm
Jamiehol
Just had a quick look to see if I bookmarked where I bought my kit from and I didn't, although I did come across this place http://www.lrspareparts.com/eshop/13-pin-t...-7410.html
Post #329529 26th May 2015 9:34pm
Weegie
The one they supplied is the same as the one CamTechCraig posted on another thread. It works properly. John
GAP iiD BT-Sold
Post #329532 26th May 2015 9:48pm
Zirconblue
I've just emailed them to confirm what they're selling is the genuine part pictured and not the Britpart/PF Jones aftermarket one.
Post #329535 26th May 2015 9:56pm
Zirconblue
I expect they do, but i'd like to try and keep the car using OE parts if possible. I already have the original control unit with the 7 pin electrics.
Post #329536 26th May 2015 9:57pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
The one I got from P F Jones is a Westfalia item
New ecu (same as the one for the 7 pin unit), but the loom has an extra relay in it.
Remove your 7 pin unit and fit the 13 pin unit, then sell on your old 7 pin unit.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #329681 27th May 2015 8:55pm
Zirconblue
Thanks, i have emailed them to enquire about it, but they haven't replied yet.
Post #329707 27th May 2015 11:01pm
Re: Towing electrics pre-2006 vs. post-2006
Harness was the same from 02my-09my either in 7 or 13pin guise. The ECU from your existing kit will work on both looms sir Thumbs Up
Post #329713 27th May 2015 11:19pm
Zirconblue
I thought it might be, they've obviously just changed the length or colour of something slightly. So it's generated a new part number. Which they listed as 06 onwards!
Post #329722 27th May 2015 11:43pm
Zirconblue
Westfalia kit arrived from PF Jones today along with the farmers hitch.
Will be fitting that this week.
Post #330489 1st Jun 2015 10:36pm
