Home > Technical (L322) > Transafe fail prog error please help...
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi, ive had this message come up a couple of times now since owning my TD6 and i have to switch off for 30 sec then back on and its ok. The gearbox seems to shift smoothly and not noticed any clonks etc. The hill decent and low range also work fine with no problems. The car has done 106k miles now. What could the possible causes be? as per my other thread would you recommend an oil and filter change for the gbox. Thanks
Post #329743 28th May 2015 9:57am
same here,
http://www.fullfatrr.com/forum/post329740.html#329740 ... - .- -.
Post #329754 28th May 2015 11:02am
William97841
I had this problem driving me mad anyways I took out the battery after 10mins and found abut of corrosion by the transfer box ecu so i got another ecu plus the harness from transfer box and ecu and also cleaned up the terminals between below the ecu and touch wood everything seems to be ok after 3k miles.
Might help ya
Post #329758 28th May 2015 11:24am
As well as above, it can do it when the battery starts to fail....
Get the codes read, it should have stored something to give you an idea... Pete
Post #329762 28th May 2015 11:39am
JPS
Thanks, I didn't think there could be anything majorly wrong with the gearbox as over the last 6 months it has only done it 3 times.
Post #329906 29th May 2015 11:00am
It trips this fault when the input and output speed sensors don't agree with each other (or a worn battery!!)
Mine only did it when off roading in low box, did it a few times... then gearbox went Kaput...!!!
Did take 16,000 miles though..... Pete
Post #329994 29th May 2015 10:59pm
