Home > Technical (L322) > axle articulation validity fault |
Possibly reversed one of the height sensors. Have a search on here there are a few threads on it, they can get over extended and basically flipped over.
27th May 2015 10:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7941 |
What he said....^^^
27th May 2015 10:37pm |
DoverVogue Member Since: 14 Apr 2014 Location: Dover Kent Posts: 4 |
Thanks, ive had it in the air before with no prolems but I'll take a look tomorrow evening in the light and see if ones been knocked off or something. |
27th May 2015 10:46pm |
N/s/r sensor has a snapped arm. New one it is then |
28th May 2015 4:37pm |
Quick fix if you need to use it.. take the old arm off, use a metal coat hanger and make a rod with loops at the end that is the same length as the original, make the loops slightly larger than the end of the nipples that locate it, put the new rod on and slightly flatten the loops with a pair of pliers to stop it falling off.... job done... Pete
28th May 2015 4:59pm |
I'll keep that in mind if I get stuck. I always have cable ties and gaffer tape handy just in case! |
28th May 2015 7:54pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Guess it depends on which bit of arm has snapped, the metal bit or the plastic bit?
29th May 2015 5:09am |
ammar Member Since: 10 Jun 2018 Location: Bedford Posts: 9 |
Hi,
28th Dec 2018 2:44am |
