![]() | Home > Maintenance & Mods (L322) > Rear screen washer nozzle |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
Unfortunatly it is not available on its own from the dealers you have to buy the wiper arm to get the washer cover, iv'e been quoted £34 inc VAT which for a dealer isnt to bad |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
I picked up a new wiper arm which includes the cap containing the nozzles. Unfortunately, it seems that the part that the cap fits to in order to supply fluid to the screen (broken off as per my picture) is a part of the wiper motor assembly and is not available separately. |
I had to have a replacment motor due to it leaking, around £100 used or £150ish pattern part but only a 30 minute job and easy to do |
Yes; not difficult, but extremely annoying if the motor etc are fine - just a tiny but of plastic broken. |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
Done it myself
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Do any of the BMW rear wiper motors actually fit as a complete unit? |
the bmw compact looks the closest but the mounting is still wrong. I spent quite a lot of time comparing images with the FF rear wiper
'Glad I'm not the only one! There must be a nipple that would fit if you drilled out the old - if only one could locate it. I have effectively done the same as you so far. |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 116 ![]() ![]() ![]() |
My Seat Leon has a very similar system. I drilled out the broken tube and threaded through a small bore piece of washer tubing. The spray head pushes into it, and the washer spindle just fine, and it connected up at the other end with a standard push fit connector. Just make sure to leave enough slack in the tube to allow for the movement of the wiper arm.
Sounds good. Do you not get a leak where the tube meets the cap? The original arrangement looks as though it relies on a tight fit between the spindle part and the cap. |
