Home > Technical (L322) > L322 fuel pump leak...
D8DEL
Scotland 2006 Range Rover Vogue Td6 Bonatti Grey
Hi folks, has anyone experienced their main pump leaking diesel when running?.
I noticed it when I was checking the ball joints on the steering rack and it was dripping pretty bad.
I can't properly see where it's coming from as there is another pump in the way.
What's the process and is it do-able at home?.
Cheers in advance, Del. "Scotland is poorer in Men but richer in Heroes"
Post #330241 31st May 2015 2:29pm
Where is the leak coming from. You have two pumps, one in the tank and the other under a cover by the LR wheelarch?
If the leak is in the engine bay then it is coming from somewhere else?
[edit] see below for correction! .
Post #330250 31st May 2015 3:10pm
Zirconblue
I'm not an expert on the TD6, but there should be 3 Fuel pumps.
The lift pumps in and beside the tank. But there should also be a high pressure distribution pump, which i would assume it located under the bonnet?
Post #330252 31st May 2015 3:25pm
You are right - the injection pump, tucked away under the inlet manifold, looks like a right pig to get at, lots of dismantling, coolant drain down, but it could just be some loose connection. Not for faint-hearted, also a couple of special tools for releasing sprocket from pump.
For future reference: injection pump listed under engine management system in RAVE, the other two pumps under fuel delivery system, hence my omission Smile .
Post #330267 31st May 2015 5:19pm
D8DEL
Hi guys, thanks for the replies and the guidance.
It's the pump under the bonnet, n/s behind the whole front end.
Hopefully it's something that's loose and not needing a new pump but I was just putting it out there for help to see if these are prone to seals going, hence needing replaced. "Scotland is poorer in Men but richer in Heroes"
Post #330276 31st May 2015 5:45pm
Mikey
They are quite prone to leaking. If it gets much worse, eventually it won't start.
Same happened to the sister in laws car a few weeks back.
You can buy seal kits, but they seem to be a bit hit and miss whether they work or not...
Post #330281 31st May 2015 6:00pm
acc
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
If it is the pipe from the fuel filter to the injector pump, I had the same issue last year. The pipe also has a take off for the FBH. I found out it is a LR supply only part, but Craddocks got me one and with postage it wasn't cheap. £92:00.
My one that the end of the pipe onto the pump had perished.
Alan
Post #331399 7th Jun 2015 3:34pm
D8DEL
Thanks for the replies guys.
I'll strip her down to see if it's an easy fix and put her right.
I love my Vogue so she'll get the best treatment to get her back up to speed.
Cheers again, Del. "Scotland is poorer in Men but richer in Heroes"
Post #331411 7th Jun 2015 6:12pm
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Hi, did you have any luck sealing/sorting your fuel leak? 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #378069 17th Mar 2016 8:29pm
