![]() | Home > Maintenance & Mods (L322) > Noticed red fluid/droplets on engine tray underneath |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
You've either got the wrong fluid in the gearbox and that's leaking or it could be from the power steering or red coolant..
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
It is watery looking. It's been looked after by an independent LR specialist. I'll take another look when it's not raining. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Probably coolant then - they run with red anti-freeze |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
there are a couple of pipes at the back of the heads that can fail apparently.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Rads often rot out in the bottom |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
If it's towards the front of the engine tray, check the power steering hoses.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Stick your finger in it and have a taste ....you'll soon know if it's antifreeze. ....very very sweet! |
OK thanks for the info. The radiator has been replaced a year or so back. I had a look under the hood this morning and nothing obvious. Again, it looks like I will be taking it in somewhere.
Passenger side at the front, coolant reservoir, take the top of slowly, then a little rod should pop up and show you the level... if it was a decent leak the FF would have bonged at you anyway and displayed "low coolant" so it won't be much of a leak... Pete
Thanks for the info. I'll have to have a look under the hood again when the rain has stopped. I can't re-call seeing anything like that. I know on the right at the front is the windscreen washer reservoir, then to the left of that, I believe the oil filter housing. Will take another look, mine has had the 2006 facelift so some things where I expect them to be around the headlight area are not.
Just another thought ... it's not lightly to be auto transmission fluid is it? What colour is that? |
As in my first post, if it's got the wrong oil it could well be red, it should be engine oil coloured....
Thanks guys. I think I found the source and it does indeed look like its coolant. I noticed when looking from above the engine that at the bottom of the engine tray on the right, there is a build up of the pink stuff;
1. Yes, look at the diagram drawn on the top of your coolant tank, it shows where the round bits in the float should be with the coolant at the correct level.
