![]() | Home > Technical (L322) > Frustrating Indicator problem M62 03 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Mine did the same when i drowned it in a river, the BECM was underwater, was fine when taken out and cleaned and dried properly (it's under the passenger seat by the way) My LCM did not get wet.... so I would think your problem lies within the BECM, AFAIK these have to be coded to the vehicle and I did read somewhere that you can't recode a second hand one.... this maybe rubbish though...
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Possibly unrelated, but my parents old Citroen C5, started doing random stuff just like that. A new battery cured it. |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Thank you. That is very useful.
Passenger seat out, four bolts and one large elec plug (don't turn ign on with seat unplugged or you get a airbag light and need an IID tool or similar to reset it) It's pretty heavy and you have to be careful you don't wreck the door card getting it out... Disconnect the battery first, procedure in the WIKI (Link top right of this page)
Do you have a tow bar? I'm wondering if the lighting electrics in the back got wet... |
Thank you for the details and photo's. That looks like a weekend job.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Right hand cover in boot (fusebox behind) you will see a white box around the size of a fag packet, in line & just behind your drivers side rear light. There is a white plug (next to the box) that’s the loom that goes to your trailer socket and ECU, simply unplug the white plug sir |
Cheers
Typically the indicators did not come on (own their own) at all yesterday.
Update.....
That's a shame, just try it and see if it cures the fault, if it does see if you can get it reprogrammed... Pete
Well fitted the new (used) LCM tonight. Lights all function correctly but I have two black dots within the mileage on the trip miles as expected
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
I had the same prob with mine and fitting a used LCM sorted it. I just live with the tamper dot and made a note of when it was changed. I think anybody buying a 10 year old vehicle if shown why there is tamper dot and shown the exchanged part ( I have kept the old one) would understand. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
