Home > Maintenance & Mods (L322) > Help - Mantec bash plate, cant fit, missing a mounting point
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Hi All,
Need some help... I ordered a bash plate (front sump guard) from Mantec. It arrived and my simple (4 bolt) fitting went South when I discovered the old owner has managed to "remove" (?) one mounting point. LR in Brisbane (Australia) said they cant help - referred me to a crash repairer; Crash repairer (reputable Brisbane one) said "No" its classified as a repair to the front cross member so we can't do it. (Structurally its fine, just a License thing they said).
So, I guess I need to find a wrecked L322 and remove the part - metal plate per photos) (as LR dont seem to classify it as a "part") or make something up (I'd prefer to use this as the mounting point than try and mount alterantively); and then find a friend who will weld it on......anyone help with the plate in the UK????
cheers
Chris
Brisbane AUSTRALIA
<img>
<img> 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #330905 4th Jun 2015 6:11am
I'm sure there would be plenty blacksmiths, welders, metal workers outwit the LR or Crash Repair scene who are local to you who could fabricate something for you. I really don't see any problem having it made as it's just a lump of metal
Post #330915 4th Jun 2015 8:53am
No pictures showing for me...?? Pete
Post #330926 4th Jun 2015 9:54am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Show ok for me Pete (when you click on the green linky) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #330946 4th Jun 2015 1:07pm
Post #330955 4th Jun 2015 1:34pm
That is part of the front subframe not the engine main frame at the front. it is just a plate welded on, it won't be available separately. If your having trouble getting someone to do it on the car then take it off and take it to a welding shop and say you want it to look like the other side... Bumper crash bar, and a few other bits off and it unbolts
Or get a second hand one from a breaker... Pete
Post #330987 4th Jun 2015 5:47pm
Zirconblue
It's just a flat plate. Any metal fabricator car knock that up for you in 1/2 hour. Get a bit of cardboard and cut to the same shape as the one you have (ie trace it and cut it out), then offer it up to make sure it fits the other side. The bit of cardboard will be the template for making the new bracket.
Any metal fabricator or a decent back street garage can cut it out of an off cut of steel for you and drill the hole in it. I think i would try a workshop that deals with heavy Plant or Lorries as they're more likely to have that sort of gauge steel sitting in the scrap bin. At a guess i reckon it would take under an hour to cut it out with an angle grinder and weld it on.
Failing that just buy a complete second hand front frame and replace it as a whole.
Post #330990 4th Jun 2015 5:56pm
BlackPerth
Thanks all, Zirconblue, I will be going down that path Smile 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #331059 4th Jun 2015 11:21pm
