Home > Maintenance & Mods (L322) > Pagid - front pads
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Pagid - front pads
I know much has been said about choice of front pads but just to add my two pennies, After getting a quote of nearly £400 from my local main stealer, I went for Pagid for my 4.4TDV8 with brembo's. £90.
I believe the name is just a marketing licence for Eurocarparts these days but I am very impressed with the performance of the pads. (no i don't work for them Laughing ) They seem to bite a little more aggressively as they heat up and more progressive with increasing foot pressure.
Oh and just to add what others have written about the retaining pins....they are the spawn of satan. "tap them out" they say... Big Cry Big Cry ..lololol...more like break/bend/ blunt any kind of drift punch you fashion or use (including an expensive facom one) and they still didn't budge. Had to get an angle grinder and blow torch in the end Shocked . ( Replacement retaining pins / "fitting kit" from LR - £100 !!!!! Censored Censored ) Outright robbery.
Post #330864 3rd Jun 2015 8:46pm
I suppose that's why the dealer wants so much... they know what their like..
At least you got it done for half price... Thumbs Up Pete
Post #330872 3rd Jun 2015 9:30pm
Zirconblue
Re: Pagid - front pads
I wondered this too, bit they still appear to be an independent company;
http://www.pagid.com/
But ECP are obviously their sole UK distributor for LCV/automotive brakes.
Looking at their website they do brake linings for trains, ECP don't do those, saying that i've not tried, I might pop in and ask how much a set of shoes are for a Brush Class 92. Laughing
Post #330875 3rd Jun 2015 9:49pm
RiccartonRR
If I may be so bold as to offer a tip for the pins.
Find a nail which is the correct diameter - only just less than the pins.
Cut a section out of the nail which is only 10 to 15mm longer than the distance between the end of the pin and the outside edge of the caliper. This keeps the 'punch' as short as possible but still gives clearance to protect the calliper body.
Hold the section of nail vey tightly in a good set of vice / mole grips and position one end of it against the end of the pin. Then, using a large hammer (even a lump hammer) give the pin one very good thump.
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
The first one of mine I did was a nightmare using decent punches but once I adopted the above the remaining three came out no problem at all. Having said that - I guess I could have just been lucky!!
Post #330876 3rd Jun 2015 9:52pm
I bought Pagid pads for mine in a hurry just before packing off to Oz and thought I might regret it compared to genuine but no I am delighted with the pads , fantastic feel through the pedal and tremendous bite . Less choice here though so back to Brembo next time , Cherching Big Cry 2008 MY Supercharged
Post #330899 4th Jun 2015 3:20am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
WD 40. Have a brew then welly the hell out of them. I ended up with a bit of hammer rash but the bu**ers didn't defeat me! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #330907 4th Jun 2015 7:15am
Fleagle_UK
wd40 / penetrating oils / custom drifts / nails/ sacrificed screwdrivers / heat / cups of tea/ big big lump hammers / scuffed bleeding knuckles / smashed fingers / deep pain....oh the pain.
yep tried it all. Got there in the end but safe to say never come across retaining pins like that in my life and hopefully never will again. Razz
New pins went in with lots of copper slip over the interference clip - hopefully make things easier next time for me or who ever owns the car.
Post #330929 4th Jun 2015 10:26am
mzplcg
I had this when I did my previous one - 2010 S/C. What worked for me was to soak the pins in plus-gas, take it for a spirited drive Whistle to get the brakes good and hot, get the wheel off as quickly as possible and then spray the pins with aerosol freezing spray. They came out *relatively* easily then. But you do only get one go at it really, you need to be quick.
When re-assembling I cleaned everything with wire brushes and used copper grease to try and make it easier next time.
Not the best design though.
Post #330931 4th Jun 2015 10:43am
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi,
Used pagid on my last car and found both the discs and pads to be very good both in performance and lifespan. Only downside was they seem to make more brake dust.
Post #330963 4th Jun 2015 3:22pm
