![]() | Home > Maintenance & Mods (L322) > Recommended anit-freeze coolant for 2003 L322 4.4 v8? |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Folks,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8737 ![]() ![]() ![]() |
JLR specify
A picture paints a thousand words....
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
When I did mine I sed the correct G48 spec which you can buy under the Comma brand from Halfords and a lot of good motor factors. |
That picture helps. So the float needs to be poking out from cold.
Found the G48 spec Comma in Halfords and it was green so I went for a pink/red which mine already had in as per the above link I posted.
It will take over 10mins sat at idle to get up to temp, take it for a 10mile run then come home and lye underneath it...
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
The correct coolant for the 2002/03 M62 V8 (and TD6) is G48 Ethylene Glycol fluid as Hayland says (usually blue, green or pink).
My system had pink in already so I topped it up with the pink OAT ready mixed. Didn't want to mix with any other colours (green/blue) as they would react. I have no idea what type it was that was already in other than it being pink.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You can try it, if it's only a minor leak it might solve it for a while. It's only a temporary fix though, and over using it just fills the system with rubbish. But saying that it's easy enough to flush out when you eventually repair the system properly
