![]() | Home > Maintenance & Mods (L322) > Hitachi Compresso, Service Announcements + flat tyre |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
I tried the refurb on the older type compressor, didn't solve my problem, a new compressor did though....
| tafftoo Member Since: 29 Jan 2015 Location: Staffordshire Posts: 40
prior to the car dropping to its bump stops it's been having compressor issues like being slow to raise and timeouts for several months. It's been holding air fine throughout all that time and I just hadn't got round to sorting it due to moving house and whatnot. Diagnostics have not shown any other faults other than those you'd expect from a failing compressor, and despite the refurb the compressor still feels really tired. That's not to say there isn't a leak as well, but if there is a leak, having air in the system will make it easier to find.
| L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51
You should ask Meerbusch if he can help, he installed his refurb kit on mine 2 years ago, still working as good as new. |
ok, thanks, I'll drop him a PM |
| mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118
Changing the piston ring can make things better, but what condition is the cylinder bore in? If that is scored then a new ring can make it better, but not cure it.
I tried raising a corner at a time, and it doesn't seem like the compressor has enough puff to do it. The cylinder bore looked ok and I didn't see any signs of scoring although when putting the new piston seal and checking for snugness, it didn't feel quite as snug as I might have expected.
So having given up on the reconditioned (HITACHI) compressor, I've bought a new (AMK) one from Dan which arrived this morning (thank you) and now it's fitted it all seems good apart from an U0000 - Unknown Fault in the RLM Suspension ECU. Am I right to assume that this is just because I haven't updated the RLM ECU yet? |
| birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147
also check the air lines etc for leaks as a small persistent leak can over work the compressor. Aswell once pumped up it should maintain height for a while. |
The new AMK compressor seems to have fixed everything, and the IIDTool has reflashed the Suspension ECU and the fault has disappeared. Happy Days! The car feels transformed and even SWMBO agrees (unusually). Now I just need to service the beast... |
| All times are GMT |
