![]() | Home > Technical (L322) > Key Ignition Switch | 2008 Vogue SC |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
I would have thought if the battery was expired it wouldn't start the car at all. I would be looking at the key/transponder, have you tried the spare key? SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57 ![]() ![]() ![]() |
Yes I would of thought the same. Note that previous owner did advise to change the battery and that was about 5 months ago. I've tried the spare key previously noted below.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
I would start with the easiest thing first and give the battery terminals a good clean. Have a search on here there are several threads on it and it could be related to any one of the issues you have said. If it does it with both keys then I think you can probably rule out a transponder problem in the key.
Thanks will have a go at it and clean the terminals. I doubt it will do much.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1377 ![]() ![]() |
get the battery changed IMO
2nd attempt to remove (-) terminal on battery , wait 10 mins, reconnect and turn key switch, engine on success.
Went to a battery shop down the road, took a reading on the existing battery, (attached pic) guy said battery low. Previous owner did mention its best to change the battery (over 2 years old), so went ahead and changed it as it doesn't cost much, just under £70 all incl.
although for an earlier model this MAY help you
Thank you for the response dingg1. Looks great but not sure I want to go down the drilling route.
I wouldn't mind trying screen shot attached.
I'm starting to think that the mechanism that unlocks the key is maybe the problem. When the transponder is "seen" by the immoblizer reader, it disengages the steering lock and the key lock (allowing the key to turn). You can hear that mechanical noise when the key is very close to the ignition switch.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
The key transponder is passive Eugene (works on magnetic codes i think) so does NOT need key battery power to work sir |
Craig, on the older one I know but on the newer ones I noticed that it was soldered onto the PCB, so assumed that was because it needed battery power. I took the passive one out of my old style key and put in in my flip key I got through Daveo |
Ahh... Hadn’t taken a newer key apart Eugene so i stand corrected sir |
