![]() | Home > Technical (L322) > Brake Fluid Change |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
A local motor factor has Dot 4 and Dot 5 on the shelf together. When you look at the actual label it specifies it as Dot 5.1. I wonder if this is common as it can be quite confusing. My understanding is that, as you say, Dot 5.1 can be used (is better) but Dot 5 is a no no. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
If i remember correctly DOT 5 can't be mixed with DOT 4, but DOT 5.1 can. So i think they're saying you have to flush the whole system through if you use DOT5, you can't just top up DOT 4 with it. |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
It doesn't help the DOT rating system for brake/clutch fluid isn't very intuitive.
Good info there. I only raised the issue of 5.1 as sometimes you get it cheaper.
. And there are a lot of Dimwits who would confuse it was antifreeze.
Stops you keeping it so long, because the tin normally rots out and when you pick it up one day the bottom falls out complete with fluid. |
| stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188
I used silicon fluid in the newly refurbished brake system on a Lotus Éclat I restored. I couldn't understand why the brakes kept on binding and spoke to Lucas who had supplied the master cylinder. The guy was scratching his head until I mentioned silicon fluid. 'That's your problem' says he, and he was correct!
| JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 269
Is this the same? http://www.k300performance.co.uk/brakes/br...uid_59.htm 2024 P550e Autobiography 2016MY TDV6 Autobiography 2011MY 5.0 SC Autobiography Black 2005 TD6 Vogue |
Yes it is the same but given that Super Blue is no longer listed on the ATE website (it's replaced by Typ200) it's more than likely old stock so I wouldn't bother.
| All times are GMT |
