![]() | Home > Maintenance & Mods (L322) > Engine Oil Overfill |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
Hi,
Chex - thanks for the info. Which garage is BHP?
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
BHP is on Ole Odume Rd but seem to focus more on Subaru/rallying so I'm not sure if they even do LR. (070) 500-0385
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
I accidentally overfilled my 2005 Td6 once (up to the dipstick max level, or so I thought …) which eventually resulted in masses of smoke (and I mean masses – really very embarrassing amounts!) coming out of the exhaust. Just draining off the excess wasn’t enough - oil had got into the intercooler so that and the hoses had to come off to be cleaned out. I understand that if you get to that sort of situation (where you have oil in the air circuit), there is the risk the motor will run on the oil fumes and you won’t be able to turn it off. Indeed it could over-rev to the extent of destroying the engine. Get it fixed quick! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums. 20 years ownership of Solihull products, ALL GONE NOW, sniff! Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee. Previous: TD6 HSE L322 Auto FF 2.5 TDi 4-door Classic Disco II And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic Not to mention the Lada Niva before those. (I said not to mention it!) |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If it's really over filled then the oil system can over pressurise and blow seals. The engine can also burn it and burning lots of it can damaged the lambda sensors and cats.
It's theoretically possible with a diesel for it to run on it's own sump oil, and you hear lots of people mentioning it on the internet and in the pub, but i'm yet to meat anyone who's actually had it happen to them. It's always a mate of a mate had it happen to him, or their brother's wife's, 3rd cousin once removed's boyfriend's dad had it happen to them. You can always turn and engine off - just stall it. A diesel running on sump oil is unlikely to have a great deal of power, so should be pretty easy. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1399 ![]() ![]() |
I've seen it happen on a turbo diesel - not a jot the driver can do about it and it leaves a REALLY impressive smoke screen
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
Zirconblue, ive had it happen to me twice sir... Both in TDi’s one FF one French and on each occasion the turbo let go and it drank the sump dry within seconds! Finished the Peugeot 1.9 TD engine (so had to be replaced) hydrolocked the 3.6 TDV8 FF which damaged an injector and snapped the starter motor! But the engine survived |
Some how i knew as soon as i posted that someone would be on here saying "I'm always doing it!" |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1421 ![]() ![]() ![]() |
I (2012 TDV8) had the same concern, as the screen was showing the oil level above the maximum. As recommended in the handbook I called the dealer for advice and was told (1) the oil level has to be checked cold, not warm after settling for 5 minutes as would have been the case traditionally; and (2) the oil level test is very sensitive to the angle at which the car is standing so for example in my garage which has a slightly uneven floor I get different readings depending on where it is. Testing cold the level showed about a quarter below the maximum or about the maximum, depending on where it was in the garage. I was also told that if it really was overfilled the car would not be running right, so if yours is running well it might just be a case of testing it cold and on a level surface.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
I did see a youtube vid of an X5 (edit found below)killing itself when it became a turbine. I guess in a manual you could try to stall it, less possible in an auto!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
^ thats a proper de-coke!!!! ... - .- -.
@Stan |
