![]() | Home > Maintenance & Mods (L322) > Rear ABS sensor seized after jacking up car?.. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Welcome to the forum |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35731 ![]() ![]() |
i'd disconnect the battery and do the lock to lock as suggested by tim ^ ..............procedure is in the wiki.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
If the cars been driven to the garage and the dash lights have still not gone off by themselves then you have a hard fault issue... The ABS sensors are always seized as they are glue’d into the hubs during production |
Shawrob72 Member Since: 07 Jun 2015 Location: Egham, surrey Posts: 3 ![]() ![]() ![]() |
I don't think there was a hardware fault with the suspension,
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I've not removed on on an L322, but they can be absolute pigs to get out on most cars. Even if they're not glued in they're usually put in dry (ie without copper grease) so they rust in there. Getting a drill on them is often a pig as you have to dismantle half the suspension just to get at it, then you find most of the fixings for that are seized too. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1385 ![]() ![]() |
drilled one out on mine - easy with plenty of room - 30 minutes at most.
