Home > Technical (L322) > U0400 fault code
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
U0400 fault code
Anyone know what the following fault code relates to? It keeps reappearing and in all my searching I cant find out what it represents and what might be causing it. My iidtool says the following:
'U0400-68 (2F) Invalid data received (event diagnostic trouble code) - Algorithm based failure - event information'
Post #330930 4th Jun 2015 10:38am
kezbo1981
I exchanged emails with GAP to see if they could shed any light on it and they said that unless there is a real issue with the specific system, U type faults should be ignored. Given that at present I don't appear to have any noticeable problem with the instrument pack I guess ignoring it is the solution!
Post #331504 8th Jun 2015 11:30am
i guess if it 'aint broken etc etc... Thumbs Up ... - .- -.
Post #331506 8th Jun 2015 11:46am
Zirconblue
I think they just mean the computer has flagged up an anomaly, which might have only lasted a fraction of a second. You could spend weeks trying to clean up connections and earths, then find it doesn't reappear without really knowing what it was causing the problem.
Hence just ignore it unless an obvious problem arises with something else.
Post #331555 8th Jun 2015 6:44pm
