![]() | Home > Technical (L322) > Westfalia removable tow bar |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
If you look on the back of the bar there is a small lever, this is the part which clicks the tow ball into position. As you push it in the receiver should lift (think lift could be press) and allows the locking pin to force the ball bearings outwards.
Andrew5331 Member Since: 26 May 2015 Location: Southlanarkshire Posts: 74 ![]() ![]() |
I sprayed with wd40 and got it to snap in it seemed fine but I took it to the local westfilia fitting centre
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Dare I say .... |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if I was you, (I have the same towbar) I would beat it a few times with a hammer and kick it about a bit, stand on it, just to make sure you have still got tension in the balls, holding it on. and fiddle with the knob without twisting it etc, -you don't want to find it comes off, on the M4! I have sometimes offered it up and sort of thought it didn't look right, and just a touch and it drops off! you could also work out a checkstrap anchor location, as insurance etc. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
there are two eyes on the armature to allow you to connect a breakaway cable or secondary coupling.
Connected to tin tent all is good electrical connection via the
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8025 ![]() ![]() ![]() |
They are because it's copied from the American system which IMHO is much better - you have twin chains or heavy cables mounted either side of the trailer tow hitch & cross them over underneath - in the event or a breakaway, the chains 'catch' the nose of the trailer before it hits the road ![]() I miss those on my L405 - my trailer has the chains, but I've got nowhere to connect them to now - I need to have a crawl underneath & see what's there. ![]() |
Here is the new work horse towing the tin tent at the storage yard
