![]() | Home > Technical (L322) > Racked off!!! ;) |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Probably. Not done a FFRR personally but I have done loads of others, all teh same principle really. See if you can get a service kit from ZF.
| Wofforduk Member Since: 08 Oct 2014 Location: Bromsgrove Posts: 9
Thanks mate
Turns out im really not sure if this is a bush.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8791
As far as I can tell you are referring to the inner track rod joint, as that is what is under the gaiter.
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
I would also suspect the inner track rod - the LHS one on mine went and it used to clunk noticeably
Check the rack securing bolts too... Have found a couple loose now which creates the most hideous knocking noise! |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Given I don't have a torque wrench (must get one) I do a lot of "tightening from memory" |
| All times are GMT |
