Home > Technical (L322) > Squeakin' an Squealin'
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
Evening all,
2011 3.6tdv8 AB. 10-15 mins into a run, squeak/squeal from the brakes. Touch brake pedal and it goes off, release brake pedal, comes back. speed up, squeak gets faster..... Shocked
Bloody annoying. and embarrassing. Embarassed
I know its listed on here somewhere, but just want to be sure before the weekend.
Thanks all, in advance. Bow down
 2011 TDV8 Autobiography
Post #333175 18th Jun 2015 5:51pm
Mikey
Rear brake pads seized in the carriers, or sticky slide pins Thumbs Up
Post #333177 18th Jun 2015 5:58pm
BigPete
Ahhhhh Cheers mate.
Copious amounts of copper grease then??? Rolling Eyes 2011 TDV8 Autobiography
Post #333178 18th Jun 2015 6:00pm
Zirconblue
Sometimes you get the same symptoms from grit stuck betweem the splash shields and the disc. Giving the splash shields a bash with a screw driver handle and reversing the car for a few yards can often cure it. Nothing lost if it doesn't work.
Post #333185 18th Jun 2015 6:34pm
Need to take the calipers carriers off and clean them out with a file to let the pads slide in the retaining clips.
Copper grease on the back of the pads, and away you go! There is nothing that can't be fixed with a hammer😜😜
Post #333221 18th Jun 2015 8:16pm
