![]() | Home > Maintenance & Mods (L322) > Basic air-con check? |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
My air con does not seem to do anything - so I'd like to check it myself (as far as I can) before going to get it looked at by a mechanic - I rang the previous owner to ask if they had maybe disabled it but they say they never used it as they were told it "used too much fuel" and they just opened the roof and windows - now I'm heading to a car show tomorrow and I know its dusty out there and would like it to work (my local Halfords can check and re-gas it if needs be) so is there a basic "to-do" list first? like fuse or belts? I suppose I should read the manual but I usually like to ask other owners first in case it's something silly and I go up to Halfords and they tell me the belts been removed (or something equally as daft) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
best left to the experts ....if the a/c has never been used then theres the possibility that the seals have dried up so unless you are very lucky it might be an expensive repair.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Wherever you go ask them to do a leak test as recharging with a leak will only mean losing the gas. John
Unfortunately, the idiots that owned it did you a diservice. Like Stan said, the seals are likely to have dried out, the coolant (and lubrication) gone so if you try to run it (for a while) it is likely to do some damage.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Proper A/C people will leak test first before adding any gas |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If the gas has leaked out, then the compressor clutch will be disabled by the pressure switch, so running it like it shouldn't do any damage.
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Needs testing with ofn first.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
kwik fit can do a vacuum test on it and a pressure test to see if there is any gas in the system, and whether there is a leak.
Cheers - Just found out local garage has the kit to test and recharge etc so will leave it with them - hopefully its something simple |
destructimo Member Since: 24 Apr 2013 Location: Kent Posts: 76 ![]() ![]() ![]() |
Hi Brian,
