![]() | Home > Maintenance & Mods (L322) > TD6_Billowing white smoke_help? |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Hi Matricks, TDV6? It must be an L405 then? Is it still covered by the manufacturers warranty?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
If it is a TDV6 405, then i would sit tight and call LR assist.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
could be a tdv6 sport, if so you're on the wrong forum.. ... - .- -.
Matricks Member Since: 19 Jun 2015 Location: Wilts Posts: 17 ![]() ![]() |
Thanks,
Not heard of an intercooler failing, after all it is an air to air cooler, running at relatively low pressure, so unlikely to hole due to corrosion.
Thanks mate,
edit to above. could be the crank breather, loads of folks have swapped them out for the BMW vortex version, its a straight swap.
Thanks again,
Not sure TBH, but I'm sure one of the knowledgable TD6 owners will be along at some point to help out. The have all gone to bed early with a cocoa........or to the pub |
Thanks,
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi. Pete haylands wrote on a thread a while ago, stating white smoke could be a sign of vacuum leak from servo into vacuum system, hence brake fluid burning off. I'm sure that he will correct me if I'm wrong.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Check the radiator coolant for oil on top. I thought white exhaust meant water getting burnt. Which means head gasket or cracked head. Of these two I'd bet the first as hadn't heard of a head cracking. ______________________________
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1848 ![]() ![]() |
Turbo gone, or crankcase breather blocked.
Thanks for all the advice/ pointers - far more useful than another RR Forum I posted on.
