![]() | Home > Maintenance & Mods (L322) > Air con woes |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Took the FF to a tyre place last week to get the air con done. This garage is a large outfit that's been running for years and not something I would describe as a back street garage.
Your hoses could have been leaking at the joints though which you can never prove now they've been undone.
The guy pointed to the flexible sections of the hoses and told me they were leaking from there. As its 13yrs old and 128k miles, I thought it possible that rubber hoses will perish over time.
Update
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35675 ![]() ![]() |
common fault that...i had to replace mine cos its right at the front and gets stone damage .... ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8573 ![]() ![]() ![]() |
As Stan says, common fault, idiot at garage should know as well..... if it's not been working for a while the oil in the system will drain down to the lowest points and away from the rubber seals in the system, you put the dye in and it will show leaks from everywhere....
I want to get the old pipes pressure tested now, as I'm not convinced there was anything wrong with them. If they come back ok, I'll be sending them the bill for them 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I feel your annoyance but you have taken them off now, they will just say they aren't the ones fitted that we said were leaking...... Pete
