Home > Maintenance & Mods (L322) > 06 Facelift RR load bay cover
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all
Will the load bay / luggage cover from the 2002 to 2006 (pre-facelift) fit in the 2006 facelift load bay?
Thanks
Post #326123 5th May 2015 2:44pm
georgedb
any feedback?
Post #333587 20th Jun 2015 3:19pm
have a look at the part numbers on lrparts.ru against your vin. there are many options depending on vin and colour, so its not a straightforward answer.
I would expect it should fit but double check on the above microcat site.
options - rangerover gcat 2002-2009 - box 5 body and paint - box 50105 internal trim and fixtures. There is nothing that can't be fixed with a hammer😜😜
M3 3.2 EVO Convertible Techno Violet
Post #333591 20th Jun 2015 3:42pm
georgedb
Thanks northernmonkeyjones I will have a look there
Post #333691 21st Jun 2015 2:50am
verydisco
I have 2 identical LR genuine rigid boot trays in the 2002 L322 and the 2012 one if that helps. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #333860 22nd Jun 2015 8:09am
georgedb
Thanks VD. That should help. Cheers
Post #333889 22nd Jun 2015 12:53pm
verydisco
I also have the rubber boot mat on both, same deal, works on both. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #333892 22nd Jun 2015 1:09pm
georgedb
Thank you so much. Thumbs Up
All confirmed to remain on the-do list then along with replacing the cracked tail lights
Post #333940 22nd Jun 2015 3:53pm
