Home > Technical (L322) > L322 - trans failsafe, resolved?
Cheet22
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Just sharing recent experience.
For past 2-3 months i have been getting trans failsafe message as soon as key in ignition in the morning or after car stood for a while. Take key out and back in (sometimes twice) and it goes away and no further issue. No issued when driving whatsoever, but this was happening increasingly - from 3 or 4 times a week to every day without fail more recently.
Had local indy clear all codes - he said it had a lot of canbus errors. I have my own scanner and it just kept showing 'gear switch fault' so i was leaning towards ignition switch or inihibitor switch.
However, and i hope sharing this does not tempt fate here....whilst spending last weekend fitting a new android unit i had battery off pretty much for 30 or so hours. Of course i also ripped out the head unit and amp etc to replace with android, but since i did this, not had one single occurence of the error!? Thats now 8 days and counting
So maybe, a good period off battery has cleared something? Dunno, but might be worth a shot if you have this problem.
Post #333574 20th Jun 2015 1:55pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
You may have had a small power drain in your old amp or head unit ? Which was draining the battery !
Post #333589 20th Jun 2015 4:32pm
It's the Android head unit, they come with a "fix your gearbox" app as standard..... Told you they were good... Whistle Whistle
I think birchyman could have it, it's usually the GPS DVD that causes a drain.... If you use it ever day it will still start but I bet the voltage was in the high 11's which is enough to upset the delicate balance our FF's have....
Glad it's sorted.... hope it continues.... Pete
Post #333606 20th Jun 2015 6:02pm
Cheet22
Well guys, it seems its all down to Pete once again then!
Paul
Post #333640 20th Jun 2015 8:32pm
