![]() | Home > Technical (L322) > FFRR MY07 - HVAC unit not shutting down, not FSR |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I believe some have two FSRs, the second serving the rear compartment, so it could be that? Another thing you could try is a different HVAC ecu/switch panel, you can get good used ones quite cheaply (I recently bought two when tracing a fault). |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
The rear ACs are controlled by a button on the front panel. In the two weeks we've had the car, we've rarely had the rear AC ON. Do you think that the front "AC sensor fan" would suck air if it had something with the rear AC's FSR? I'm not sure how these systems interconnect... |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
I had the same problem with my 2003, I took it to my local specialist who downloaded a software upgrade which solved the problem. My Motto: If you are going to have one, have a BIG one! |
There was this "HVAC wiring harness" that some have installed, but I thought this was primarily for the pre 2006 models? I cannot find any store that has this harness anymore...
This weekend I'll systematically try to find the fuse that is causing the most drainage when the car is parked. I will install a longer earth cable (between the battery and ground-connection) so that I can use theC lamp Multimeter without the field-noise from the other cables in the battery case.
Most likely I need to try your approach. Is it difficult to replace the rear FSR? And do you know the part number and where to buy the rear FSR? I have, as said, bought and replaced the front FSR - many web shops have that part. But I haven't found the rear one yet. And - where to buy a new HVAC ECU/switch panel? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Just a thought.... you do know that the car "stays awake" for about 16 mins after you switch it off, it also wakes up if you open a door etc when it is asleep...
Thanks, Haylands - yes, I know that the car will be awake some time after I've locked it. The problem is that the fan is still going 2 hours, 10 hours and 24 hours after it's been parked. I can observe that through the window - I've placed a small piece of light paper tissue that gets sucked onto the fan inlet on the console. I've also stripped the bonnet sensor (that register when the bonnet is openend), so that I can measure the amps from the battery hours after the car have been locked. |
Oh right, was just a random thought.... maybe it is the other FSR...
I'm considering trying the fix described in this post: http://www.rangerovers.net/forum/6-range-r...-49-a.html - check post #5 in that thread:
Anyone tried that? Is it not recommended to disconnect the fan/HVAC ECU when one turns the ignition off? |
Trouble with that is, your not fixing the problem, your fixing the symptoms. Personally I'd want to get to the bottom of the problem... Pete
Yes, you're right Haylands, It doesn't seem right, but if the problem is a very odd behaviuor in either the BT/remote/control unit that causes the system not to go to sleep, and it is problematic to replace/fix that problem, I thought that this fix could be an easy way out... Better than having to pull a fuse eash time one park the car for a lo ger period of time. |
I thought the BT problem only happened if you were using the phone when you turned the car off...
I tried this procedure yesterday, but I made a minor mistake: I connected the + from the spare piggy-back KEY ON to the + on fuse #12 (should of course connected this to the north part of fuse #12…) – nothing wrong happened other than the “Ignition key inserted” warning turned on. I therefore reconnected to the original set up – inserted the fuse #12 and removed the piggy-back one. It also struck me that the Pre-heater will most likely not work if the fuse #12 is disconnected.
I've noticed something that might correlate with the strange behavior: If I open the hatch door after I’ve driven the car, the car finally goes to sleep. If I do not open the hatch door after I’ve turned off the ignition, just lock the car with the remote, it won’t shut down (the HVAC continues to be active). Anyone experienced this same behavior? L460 P550e AB SWB MY24
