![]() | Home > In Car Electronics (L322) > Cigar Lighters |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276 ![]() ![]() ![]() |
I am still chasing this. I removed the bridge in the relay socket and replaced with a 4 pin relay. I now get ignition switched cigar lighter and ancillary sockets BUT only in ignition position 2 or with the engine running. I have checked with Cheet2 and he has a similar situation. I have spoken with an auto electrician and he has tried different relays without success. Either there is a specific relay that is needed or some wiring change.
Afraid it is being more complicated than that. A 4 pin relay gives the same symptoms. Live on ignition 2 but not on ignition 1 (despite the circuit diagram indicating Ignition 1).
Pietertje,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
Weegie,
I now understand what you mean. |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Weegie thanks for your thoughts. I wish to make all (or at least the aux sockets) ignition switched.
You need a 12V 20A 4 pin relay only, 24V will not work.
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
I am planning to wire up a smart relay by taking a tap off the existing rear socket to give a second switched 12v socket
Having a poke around to see whats involved in changing my permanently live cigar sockets to ignition controlled I found this gadget in the fuseboard position where a relay should be mounted for ignition controlled.
Hi Nicedayforit,
Not so much a fuse as a bridging piece, the two contacts provide a link between terminals 30 and 87 of a normal 30A relay.
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
It appears as though the first L322s had the cigar outlets (and cubby box AUX outlet) wired directly from Fuse 1 (rear fuses). Then (fairly quickly) a more complex set up was introduced to allow for different configurations in different jurisdictions. For instance in Australia the design rules (in 2002) required cigar lighters to be off when the ignition is off whilst in the UK they should remain on.
BackinBlack Member Since: 10 Dec 2018 Location: Manchester Posts: 18 ![]() ![]() ![]() |
