Home > Technical (L322) > 3.6 TDV8 EGR options?
Page 5 of 5 <12345
RiccartonRR
I went for a re-furb turbo with a 12 month warranty (probably won't keep the car much longer) which cost 360+vat plus fitting which was 320+vat including oil change.
If your indie has good software, not just generic code reading, he'll be able to see the live values which will more than confirm the problem. In my case we could plainly see the boost figures the ECU was calling for but only one turbo was doing anything - the other was zero.
On the other hand we could see the values for the EGRs and both were functioning correctly. I believe these figures can be viewed with an IID BT tool but I'm happy to be corrected there.
One other wee thing you could try is using a torch etc lie underneath your car and look at the suspect turbo. Get someone else to turn the ignition to position II and wait for a few seconds. With mine the faulty unit rapidly went through it's full movement clanging at each stroke as the ECU tried to calibrate them. As the positioning of the turbo actuator was my problem (and not the drive itself but it's the same unit) then the ECU had no idea where it was hence rapid stroking / clanging.
Good luck Thumbs Up
Post #334438 25th Jun 2015 8:26pm
RiccartonRR
Ooops - should have mentioned - I got a price from Dan@Duckworths which was fantastic for a Garret unit (not exchange) at approx' £855 IIRC but like I said, I'm not too sure how long I'll have her.
Post #334439 25th Jun 2015 8:28pm
Mikey
An EGR code will be logged, if there is a genuine EGR issue
If it is only an actuator, or boost pressure code being logged, then it is likely to be a seized actuator, or boost leak in the system
With the IID, you can watch the actuators move rough their full range of travel, as well as EGR command and position Thumbs Up
First port of call is to find out what fault codes are being logged Thumbs Up
Post #334457 25th Jun 2015 9:31pm
The Indy that checked the O/S turbo when the fault first appeared and confirmed the actuator wasn't stiuck, or sticking.
I have the fault codes somewhere and they pointed to an actuator issue but the physical check showed that it was moving freely. As I understand it, there's also an electrical actuator inside the turbo unit?
I'm struggling to understand how a seized actuator can disappear for days and no errors are reported. Got - 2017 SDV8 Autobiography in Loire Blue
Post #334506 26th Jun 2015 11:13am
Mikey
Depending on the code, it may not be a physical actuator fault, but a boost pressure fault Thumbs Up
As said, live data is the next step Thumbs Up
Post #334514 26th Jun 2015 11:58am
So a BT IIDTool would do the job?
I've been looking for a good reason/excuse to upgrade my non-BT! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #334515 26th Jun 2015 12:18pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Our one is going in for its annual service Monday, my indy is trying to talk me in to a 're-map, says it will map out the egr valves, increase power, and improve consumption, with the exception of mapping out the troublesome egr`s, I'm not particularly bothered about the other stuff.
Any one have any thoughts on doing this?
It will cost €600, but I really don't want to cause any problems later.
Post #334517 26th Jun 2015 12:43pm
Mikey
A non-BT tool will also do the job, but is a bit awkward to navigate and compare without the graphs
Speak to Patrick @ Gap about upgrading. I know there have been a lot of D3 owners upgrade recently Thumbs Up
Post #334565 26th Jun 2015 5:49pm
That's what I'm thinking Mike, non-BT without the live value graphs wouldn't really help I don't think? Got - 2017 SDV8 Autobiography in Loire Blue
Post #334632 26th Jun 2015 11:24pm
Eirik34
Norway
Hi, today we've got our first two EGR related error codes - and the amber engine warning light - on our TDV8. The code read from the IID BT tool was "P140A-21 (2C)". After investigating this a bit, I found that it is related to the left EGR, signal low.
My first thinking was that: Now it's time to try to map both the EGRs out! But after discussing this with Pete at BAS, it seems that mapping the EGRs out is not that simple. One need to blank the EGRs out as well....
I know that the IID BT tool is capable of giving live feeds, do anyone know what/how to use this tool to find out more regarding the EGRs and in particular the turbos - to increase the likelyhood of a sucessful repair?
Post #338756 23rd Jul 2015 9:11pm
Eirik34
Norway
I’ve used and recorded live values from the IID BT tool, but I’m not an expert (to put it mildly!) to analyze and draw a conclusion based on these readings. To me it seems that the left EGR valve is less open (lower position values) than the right. When the EGR error code appears, the left EGR valve (#1) is stuck at max 5% opening.
However, when using live values it happens often that some live values freeze, and the feed of these values are sent to the iPad as a bulk stream at the end of the live values recording session. It seems that there is something wrong with the time stamp of the recordings.
Post #340707 4th Aug 2015 11:26am
rar110
I would try a Revive treatment for turbo and EGR problems. I used it on the RRV when I thought fuel consumption was up a bit. The motor had noticeably more power & seemed smoother running, not that it was running rough. I also used it on the Peugeot 407 hdi which had an EGR related surging problem. We initially fitted a blanking plate which fixed the problem, but then removed the plate used the Revive treatment. The surging hasn't returned. These are my only experiences with this product but both were positive. ______________________________
Post #341559 9th Aug 2015 10:42pm
Page 5 of 5 <12345
