Home > General > How Noisy is a V8 Supercharged?
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi Folks
I had a look at a 2012 V8 Supercharged AB yesterday here in Kampala. 2012, 71000 miles. I've never seen one before!
Needless to say is was beautiful, has almost everything I think including those deployable side runners, starts on the button. Message on the dash stated service overdue.
Lifted the bonnet and it struck me as very noisy for a V8! Almost rattely. My only experience with V8s is from my D2 V8 which sounded much better than this. Put the bonnet down and again struck me as noisy for a petrol.
Are they like that?
Cheers Jerry
Post #334787 28th Jun 2015 5:33am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
My SC is very quiet, suspect something is adrift with the engine Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #334793 28th Jun 2015 8:05am
Mikey
There was a TSB released about noisy timing chains Thumbs Up
Post #334795 28th Jun 2015 8:15am
Road Stone
Thank you for the replies
Can anybody elaborate on the issues and what happens if nothing is done, ie how serious is it?
Cheers. Jerry
Post #335102 29th Jun 2015 6:06pm
mzplcg
The 5.0 is also direct injection which can sound a bit rattly. The injectors are quite noisy for some reason.
Post #335241 30th Jun 2015 8:10am
wealy
I have a 4.2 in my jag and you can't hear it running on tick over
Blip the throttle and it "growls" like a scalded cat.
The engine should be silent with no rattles at all.
Post #335486 1st Jul 2015 11:24pm
Road Stone
Thanks Guys,
I went back to have another look.
On start up it is noisy, no doubt about it, rattly. Then once the choke comes off is very quiet.
Quiet a strong smell of petrol, bloke stated its been sitting for sometime, needs a good run!
I checked, Its been sitting in a bond shed for 6 months.
Cheers, Jerry
Post #335524 2nd Jul 2015 10:06am
wealy
SHOULD STILL BE SILENT!
Post #335530 2nd Jul 2015 10:23am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
My newly acquired 5.0 s/c is also a bit rattly at idle. The dealer I bought it from said there was no problem but that as it is under the two year warranty I could get if fixed if it gets worse. Above mzplcg suggested the 5.0 Direct Injection may be more rattly than the 4.2. Any other 5.0 owners with comments? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #335535 2nd Jul 2015 10:41am
wealy
mine is the old 4.2 and is whisper quiet.
I don't know why direct injection would be louder, as electronic injectors have a slight "ticking" sound so if anything direct should be quieter??????
Post #335537 2nd Jul 2015 10:49am
mzplcg
Neither do I know, it just is. I have the 5.0 Rangie (2nd one now) and SWMBO used to have the 4.2 Jag. The Jag was definitely quieter.
Post #335540 2nd Jul 2015 11:45am
RR2008HSE
I've the Jag 4.4 NA. It's quiet when started cold. Once warm, it is almost silent.
Post #335585 2nd Jul 2015 6:48pm
DI petrol engines are just a little noisier, swmbo has a direct injection Skoda and it can sound a little diesely at times, when pulling off from a hill start for example but at Tickover it is quiet. There is nothing that can't be fixed with a hammer😜😜
Post #335588 2nd Jul 2015 6:59pm
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Road Stone wrote:
Thanks Guys,
Cheers, Jerry
Def should be no smell of petrol! Rings may be stuck (petrol fumes pushed past in to crank case vent system). Redex or similar may help.
Post #338456 22nd Jul 2015 8:08am
The 4.2 SC on tickover at warm can be so quiet you wonder if it's running - I know this cos NRK tried to start his up one day when we were sitting at the Eurotunnel and found it was already on.
The 5.0 can suffer from a timing chain tensioner issue, which leads to rattly timing chains. Mine had this and I had it done under warranty. It;s a huge job, took them an entire week as there's so much strip down and rebuild work. I saw a picture of my car while the work was being done and I was almost sick.
If there's a choice, walk away, as the petrol smell sounds suspect. Discovery 4 HSE
1993 90 Tdi
Post #338471 22nd Jul 2015 9:58am
