Home > Maintenance & Mods (L405) > Changing wiper blades |
Hobo729 Member Since: 14 Dec 2014 Location: Limassol Posts: 43 |
Hi Steve, you have me wondering - I had never taken much notice before because as fitted (done by LandRover Solihull) the wipers work perfectly. They do almost touch when parked and the tip of the blade almost touches the A column but as already said - they work perfectly in all respects - smooth and silent. My car is Jan 2013 and was a LandRover Director's car (very short woman driver I think) and is immaculate but the sun has now hardened the wiper rubber so they smear - hence the wish to change them. I will certainly fit both sides with 24" because the screen cleans so well with them. Thanks for making me aware. I will try the Bosch blades Alastair discovered and hope they fit OK as I don't fancy LR prices.
28th Jun 2015 12:23pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi James, you've actually got me thinking along switching to 2 x 24s when the time comes as I always prefer as much screen to be cleaned as possible and you have confirmed my thoughts about where the wipers would sit so I know it should be ok (worst case scenario is that I would have a spare 24" which wouldn't really be a problem anyway). Cheers Steve
29th Jun 2015 12:34am |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
So do the Bosch ones fit perfectly and as per original design? |
4th Jul 2015 10:35pm |
Thanks Alastair - I have fitted the Bosch Blades - both 24" - and they work perfectly. I do notice that the nearside wiper clears a much bigger area than the offside - the 4" extra makes a big difference (as the actress said to the Bishop)
12th Jul 2015 9:20pm |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 |
Does anyone have any idea on how to change the rear wiper blade?
14th Feb 2016 7:38pm |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
Just done mine, bit of a faff - the way l did it was to have the engine running, rear wiper on and open the boot when the wiper was pointing downwards. It is a 17 inch blade with a rather strange fitting which l could only find at a LR dealer and blooming expensive. Unless anyone else has any further ideas.
14th Feb 2016 10:34pm |
Jon S Member Since: 10 Aug 2016 Location: Exeter Posts: 32 |
I've bought a new blade from wiperblades.com for the rear but I can't seem to get the old one off!. It's difficult enough getting it in the right position (opening boot as it's sweeping) but it seems well fastened on there- is there some kind of tab I need to press to release it or does it just pull off? |
7th Nov 2016 3:46pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
WOW one need a university degree to change the wiper blades All my spelling errorz are belong to me!
8th Nov 2016 10:20am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7764 |
Mine was a standard fitting - I just got a regular 17" blade like this one To remove the old one, I just had to push it IIRC I'm sure Frank has someone who changes his for him |
8th Nov 2016 6:53pm |
Honestly ? I would go to my local LR dealer All my spelling errorz are belong to me!
8th Nov 2016 7:54pm |
I've done it! there is a plastic tab (that looks like a spring to keep the wiper on the screen) - I had to push this down and push the blade up out of the hook.
9th Nov 2016 11:04am |
DavidRR Member Since: 16 Dec 2017 Location: London Posts: 5 |
Have used this forum a few times now so thought it was about time I said hello and thank you. Just changed my rear wiper having opened the boot when the arm was at the 6 o'clock position. Amazing that it's such a faff but loving the results of my new Bosch blades (did fronts too).
31st Dec 2017 2:31pm |
31st Dec 2017 6:45pm |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 266 |
Shortly after buying the L405 I changed the OEM blades over to Bosch Aero. I found the LR ones noisy and the Bosch were OK at first but have since become noisy. I don’t think they are yet old enough (few months) to have worn.
2nd Feb 2018 9:21am |
