![]() | Home > Technical (L322) > Ok, so I've had it a week..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8588 ![]() ![]() ![]() |
Always teething problems... be as picky as you can, at the sort of money that cost it wants to be right with a capitol R.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
fortunately all appears to be minor problems which you wouldn't see on the forecourt and only living with the car will bring them to light.
That's a comprehensive after sales inspection nmj!
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Mine whistles and can be adjusted like yours to stop this.
This is what warranties/auc is for at the end of the day. As Ryan says, these things aren't going to come to light on a forecourt. It takes a bit of OCD to get the car perfect and most dealerships don't have that attention to detail, unless there is something obvious mechanically wrong, it won't get picked up, anything not on the checklist like the pulley will get overlooked.
What's this about "front door surrounds for corrosion" (not heard that one before)? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6781 ![]() ![]() ![]() |
^ I have that on my B pillar Ryan. LR rejected a claim against this when I had the rear tailgate replaced. Got - 2017 SDV8 Autobiography in Loire Blue
Is that that the bubbles or blisters that can show underneath the black upper door frame trims Alan/ others?
Don't think there is Ryan, perhaps a good coat of wax will help? my 57 was never affected, nor does the new one seem to be, that's not to say it won't pop up at some point! There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
09> are worse then the earlier models for corrosion |
