![]() | Home > Maintenance & Mods (L322) > Creaky Arse! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Usual creak from the rear is an upper or lower hub bush, they creak like mad when worn.... could be the shocker but my money is on a hub bush..... Pete
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Oh really? I've gotta have a proper look but is great to have a starting point!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Mine does that a bit when it's been really dry for ages. Sounds like an old spring pram.
The hub bushes are a rose joint (hiem joint) within a rubber gaiter... if they end up like mine then yes WD40 will stop them for a bit as the rubber was just about gone, but they could be worn and still have the gaiter in tact... Pete
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 ![]() ![]() ![]() |
Mine has also developed a squeaky rear but when I got SWMBO to bounce on the back bumper while I was underneath it was silent ! |
Made a cut in top and bottom bush gator and squirted a dose of white spray freeze in each. You should see the sh*t that came pouring out!
No, you can't grease anything, as I said, if the joints have got very bad and the protective rubber covering has gone, then a squirt of WD40 will shut them up for a bit, just to prove it's them..
Tel
Oh cheers Pete!
