![]() | Home > Maintenance & Mods (L322) > Air con and front screen washer jets... |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
Learned friends, can you give me some advice please.....
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8690 ![]() ![]() ![]() |
Aircon sounds like low gas...
On the washer jets, is there a single pipe from the washer bottle to both jets because both are flowing the same dribble. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Yes, both are supplied by the same pipe, fed up to bonnet above the battery |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
My pipe for the screen washers had become dislodged and when you shut the bonnet it was trapping the pipe causing hardly any water to get through, could be the same problem you are having? |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi david, some on here would advise against it but i regassed my RR with a kit i bought off ebay, its made by STP and is also available from halfords. it cost £48 but there is a £10 refund when you return the empty cylinder. it was easy to do and took about 10 mins. there is enough gas in the cylinder to top up at least twice so it might be a while before i return the empty cylinder.
But that's more expensive than getting a professional to do it..... Pete
yes pete i agree, but know i have the pipe work and gauge, the cylinders are only about £20 on there own and there is enough gas in them to regas 2 to 3 cars. with what i have left in the cylinder i can do mine again or my wifes mx5, i dont have the inconvenience of booking a appointment and waiting around, and above all i like to be independant. regards mark |
