![]() | Home > Technical (L322) > Check coolant Level fix? |
theres a possibility that it might not be the level why the warning is coming up but the mixture might not be correct.. ... - .- -.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Could I borrow your magic cloth please |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Or you need a new coolant sensor / coolant tank and sensor. .
StevoJD Member Since: 01 Mar 2015 Location: Worcester Posts: 29 ![]() ![]() ![]() |
I've got the same issue. It's going back in to the dealer for the third time in a couple of weeks so will let you know if/how they fix it. |
tafftoo Member Since: 29 Jan 2015 Location: Staffordshire Posts: 40 ![]() ![]() |
to be honest I'll be amazed if it's fixed it, but I thought I'd post it anyway as I don't really believe in coincidences where cars are concerned. So far, I haven't seen the message re-appear and I've driven the car a few times now since doing it.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
tafftoo, when was the coolant last changed? Modern antifreeze needs changing every few years!
Not sure when the coolant was last changed so I was planning on changing it at the next service anyway. As for changing the bottle and the sensor you might be right and it might be overkill, but I was thinking I'd change that at the same time anyway so that I don't have to worry about it for a few more years.
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
Took mine into local dealer for the front brake hose recall and the coolant warning came up for him, it hadn't appeared for me for a few weeks. They quoted £135 to fix it. Current:
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
The coolant sensor doesnt get wet.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
If yours is a 2002 then it should have a 140psi cap on it, not the later 200psi cap.... worth a check... says the psi on the cap... Pete
Kpa, I thinks.
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 ![]() ![]() ![]() |
[quote="stan"]theres a possibility that it might not be the level why the warning is coming up but the mixture might not be correct..[/quote]
its all in the WM George,
