![]() | Home > Technical (L322) > AC clutch not engaging |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i'd re-check the connections to make sure they are plugged in properly.. ... - .- -.
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Which connections Stan ?.
Thanks Stan, I will check this when I get a minute.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Check you have power at the connection the clutch engagement mechanism (the wires coming out of the compressor) should switch on with the ac. If you have power there then the clutch mechanism is duff. There is nothing that can't be fixed with a hammer😜😜
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
There isn't a relay, it's fed from the A/C control unit directly. As said above, check for power at the connector with the A/C engaged (you need to back probe the connector) then disconnect and check for resistance of the clutch coil to ground. It should be around 3 ohms. Outside of that then the wiring to the coil could be at fault or the clutch coil itself has gone. |
Ive unplugged it and tested the voltage to it & its getting 9.4 volts.
