![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
what I mean is that e39 oil pan is different like this
thank you for great explication, |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
It's still possible to do it on a Rangie with the correct tools, it's not easy but it is possible... Pete
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you have the symptom of pulling away and as second gear should come in, you get a massive thump and you get error transfailsafe mode, and car seems to now be in high gear and little power, then read on. its explained in full here. by RRphil. he is very knowledgable on all matters gearbox. http://www.rangerovers.net/forum/6-range-r...rdown.html
Blimey John, that's a bit drastic ![]() Top job on fixing the box though..... ![]() ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
I took that picture today, after all back together, to show where to prise apart etc. so its still got the bolts holding it together, but I had no idea how to get this apart, before I contacted you, and all was revealed. yes I wish I had considered an early cup of tea at that point. |
inform you that today at 1:00 pm another transmission has seen the sun and our 35 degrees celsius,very hot
Well done, are you going to repair it or get a new one??? Pete
i think that 1st gear is the same gear (reverse) just send backwards, with some epicyclic magic-trickery behind all the main stuff. its worth a punt to dismantle it. if you look up posts from (member) RRphil, he's possibly your man to message about specific issues. but I cant guarantee he will answer.
John, whichs eal you mean
you have to explain what you are asking a little clearer.
yes, John the ''front seal'', |
looks like you are suffering in that heat !!
thanks I'll post photos directly,
