![]() | Home > Maintenance & Mods (L322) > Wind Deflectors |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
not my cup-of-tea but many fit them,
| n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754
Cheers Stan |
i know what you mean..just come back from 1661 miles to and from switzerland and at speed you have to close the windows and therefore have to have the ac on...its nice for a bit but fresh air is better... ... - .- -.
| jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259
i've got just the fronts fitted they're made by climair
out of curiosity do they stop the windscreen washer water coming in to the cab when moving... ... - .- -.
Dunno. I'll try it tomorrow on the way to work.
try it both ways |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
I may be being a bit thick.... If you don't like the ac, why not just turn it off, turn off the recirculation, and set all to cold, with all the flow buttons pressed, and the fan at which ever setting, that way you get the outside air straight to the cabin. |
ok, not highly scientific but tried it with the window down and at half way, stationary and whilst doing 30.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I had them on the 4.2 in Nigeria as it made sense there. Not sure about here as I don't have to open the windows in pouring rain without being under some form of cover.
@mr jones, the problem with that theory is if its 25 degrees outside , it wont be long before its the same inside the cabin...
| scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140
My 2011 Vogue came with them fitted front and back, but I took them off because I didn't like the look and couldn't see the point so I am about to put them on ebay. They are secured to the window surround with double sided tape, and came off OK with no damage. Also, they are black and opaque, so do obscure the sightline a bit on the front windows. If you are still interested, PM me. 2011 Vogue TDV8 4.4
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I don’t like the look I’m afraid! |
I don't think they look too out of place |
