![]() | Home > Technical (L322) > Replacing Battery on a 2011 TDV8 4.4 - is this a DIY job? |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Am not sure on the bracket, though others will be I am sure. My only comment is after a 3rd exchange on a battery on my TDV8 I'd be inclined to give the 'highly awarded' Bosch S5 battery a wide berth. I haven't been very impressed with my replacement to the point where I have a note on my receipt to say if this one fails I want a different brand altogether. Is this where I put the car details and a bit about myself ?........ |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i dont think that 12.3 volts is a bad result...it doesnt have to be exactly 12.6 volts..
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 114 ![]() ![]() |
You don' t need reset. For extract the battery only pull the ECU with the hands. |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Thanks Guys
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I just got a 2012 and have a similar set up to the picture above. I got a new battery with it but would like to know how to do it myself next time. Has anyone actually done the change themselves? It looks much tighter than the fit on the 2007 with lots more gubbins attached around it.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I've been quite impressed with Yuasa which is what I replaced my Bosch S5 with. Like you I wasn't too impressed by it, certainly not the ~£80 premium it commands. Ed |
I think Stan is correct. Even with the new battery fitted, the Audio system shuts down after a few minutes on battery power. This must be a "feature" of this model. 2011 Vogue TDV8 4.4 1992 Mazda Mx5 |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Bosch S5’s are renowned for failing! ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788 ![]() ![]() ![]() |
Halfords are doing Yuasa batteries now. 019 100ah.
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
I'm currently looking at a new battery also.
I just checked my battery again and its now 12.7V
Checked it again this morning and 12.1v.
Ok something very strange is going on.
